[Résolu]Probleme de cross compilation
bonjour,
je souhaite ajouter une interface réseau sur mon DS216+II et j'ai acheté un module USB3/Ethernet Gigabit de marque UGREEN. Lorsque je le branche, je le vois bien apparaitre dans les modules USB :
root@synonas:~# usb-devices
T:  Bus=02 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#=  3 Spd=5000 MxCh= 0
D:  Ver= 3.00 Cls=ff(vend.) Sub=ff Prot=00 MxPS= 9 #Cfgs=  1
P:  Vendor=0b95 ProdID=1790 Rev=01.00
S:  Manufacturer=ASIX Elec. Corp.
S:  Product=AX88179
S:  SerialNumber=00000000000F85
C:  #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=496mA
I:  If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=00 Driver=(none)
Mais impossible de charger un driver, je ne trouve rien.
De lorsque que j'essaie de recompiler les modules, j'obtiens une erreur lors du make modules
drivers/usb/core/port.c: In function 'usb_hub_create_port_device':
drivers/usb/core/port.c:147:36: error: 'CONFIG_SYNO_NUM_CASTRATED_XHC' undeclared (first use in this function)
  extern char gSynoCastratedXhcAddr[CONFIG_SYNO_NUM_CASTRATED_XHC][13];
drivers/usb/core/port.c:147:36: note: each undeclared identifier is reported only once for each function it appears in
drivers/usb/core/port.c:151:35: error: 'CONFIG_SYNO_USB_VBUS_NUM_GPIO' undeclared (first use in this function)
  extern char gSynoUsbVbusHostAddr[CONFIG_SYNO_USB_VBUS_NUM_GPIO][13];
drivers/usb/core/port.c:154:6: warning: unused variable 'value' [-Wunused-variable]
  int value = 0;
drivers/usb/core/port.c:153:18: warning: unused variable 'gSynoUsbVbusGpp' [-Wunused-variable]
  extern unsigned gSynoUsbVbusGpp[CONFIG_SYNO_USB_VBUS_NUM_GPIO];
drivers/usb/core/port.c:152:13: warning: unused variable 'gSynoUsbVbusPort' [-Wunused-variable]
  extern int gSynoUsbVbusPort[CONFIG_SYNO_USB_VBUS_NUM_GPIO];
drivers/usb/core/port.c:151:14: warning: unused variable 'gSynoUsbVbusHostAddr' [-Wunused-variable]
drivers/usb/core/port.c:148:18: warning: unused variable 'gSynoCastratedXhcPortBitmap' [-Wunused-variable]
  extern unsigned gSynoCastratedXhcPortBitmap[CONFIG_SYNO_NUM_CASTRATED_XHC];
drivers/usb/core/port.c:147:14: warning: unused variable 'gSynoCastratedXhcAddr' [-Wunused-variable]
scripts/Makefile.build:308: recipe for target 'drivers/usb/core/port.o' failed
make[3]: *** [drivers/usb/core/port.o] Error 1
scripts/Makefile.build:455: recipe for target 'drivers/usb/core' failed
make[2]: *** [drivers/usb/core] Error 2
scripts/Makefile.build:455: recipe for target 'drivers/usb' failed
make[1]: *** [drivers/usb] Error 2
Makefile:800: recipe for target 'drivers' failed
make: *** [drivers] Error 2
Est-ce que l'un d'entre vous a déjà rencontré ce type d'erreur ?
Merci.
Bon j'ai réussi à compiler les driver, mais quand je tente un insmod j'ai une erreur :(
root@synonas:/tmp# insmod ax88179_178a.ko
insmod: ERROR: could not insert module ax88179_178a.ko: Unknown symbol in module
root@synonas:/tmp# insmod asix.ko
insmod: ERROR: could not insert module asix.ko: Unknown symbol in module
j'avance petit à petit :)
C'est bon j'ai trouvé ! alors il faut d'abord charger le module mii, puis usbnet puis ax88179_178a et là mon interface est bien montée ;)
  • 4 ans après...
I know this is old but I came across the same error
Learn what platform you are using
uname -a
Before you run 'make modules' copy the config file of your platform
cp -a synoconfigs/<platformname> .config
Then run 'make menuconfig' or 'make modules'
