Sick Beard Custom: Snatch Mais Ne Snatch Pas
J'ai cherché avant sur le forum, mais je n'ai pas trouvé de réponse à mon problème.
Pour vous expliquer :
SickBeard me snatch une série, par exemple Fargo, mais ne l'ajoute pas dans mon client torrent (j'utilise deluge).
J'ai ce problème uniquement avec le traquer TorrentLeech.
Ci-dessous un extrait des logs :
Jun-11 06:26:49 INFO BACKLOG :: Seeing if we need any episodes from Fargo season 1
Jun-11 06:26:49 INFO BACKLOG :: Seeing if we need any episodes from True Blood season 7
Jun-11 06:26:49 INFO BACKLOG :: Seeing if we need any episodes from The Walking Dead season 5
Jun-11 06:26:49 INFO BACKLOG :: Seeing if we need any episodes from Le Trône de fer season 4
Jun-11 06:26:49 INFO BACKLOG :: Seeing if we need any episodes from Suits season 4
Jun-11 06:26:49 INFO BACKLOG :: Running limited backlog on recently missed episodes only
Jun-11 06:21:40 INFO SEARCHQUEUE-RSS-SEARCH :: No needed episodes found on the RSS feeds
Jun-11 06:21:35 INFO FINDSUBTITLES :: Checking for subtitles
Jun-11 06:21:34 INFO SEARCHQUEUE-RSS-SEARCH :: Clearing TorrentLeech cache and updating with new information
Jun-11 06:21:33 INFO SEARCHQUEUE-RSS-SEARCH :: Searching all providers for any needed episodes
Jun-11 06:21:33 INFO SEARCHQUEUE-RSS-SEARCH :: Beginning search for new episodes on RSS
Jun-11 06:21:33 INFO SEARCHQUEUE-RSS-SEARCH :: Changing all old missing episodes to status WANTED
Jun-11 05:21:48 INFO SEARCHQUEUE-RSS-SEARCH :: Quality of Fargo.S01E09.720p.HDTV.X264-DIMENSION is HD TV
Jun-11 05:21:48 INFO SEARCHQUEUE-RSS-SEARCH :: Found result Fargo.S01E09.720p.HDTV.X264-DIMENSION at http://www.torrentleech.org/rss/download/521229/xxxxxxxxxxxxxxxx/Fargo.S01E09.720p.HDTV.X264-DIMENSION.torrent
Jun-11 05:21:36 INFO SEARCHQUEUE-RSS-SEARCH :: Clearing TorrentLeech cache and updating with new information
Jun-11 05:21:36 INFO SEARCHQUEUE-RSS-SEARCH :: Searching all providers for any needed episodes
Jun-11 05:21:36 INFO SEARCHQUEUE-RSS-SEARCH :: Beginning search for new episodes on RSS
Jun-11 05:21:35 INFO SEARCHQUEUE-RSS-SEARCH :: Changing all old missing episodes to status WANTED
Jun-11 05:21:34 INFO FINDSUBTITLES :: Checking for subtitles
Jun-11 04:21:34 INFO SEARCHQUEUE-RSS-SEARCH :: No needed episodes found on the RSS feeds
Jun-11 04:21:33 INFO SEARCHQUEUE-RSS-SEARCH :: Searching all providers for any needed episodes
Jun-11 04:21:33 INFO SEARCHQUEUE-RSS-SEARCH :: Beginning search for new episodes on RSS
Jun-11 04:21:33 INFO SEARCHQUEUE-RSS-SEARCH :: Changing all old missing episodes to status WANTED
Jun-11 04:21:33 INFO FINDSUBTITLES :: Checking for subtitles
Jun-11 04:20:07 INFO SEARCHQUEUE-BACKLOG-269613 :: Searching Cpasbien for Fargo - 1x09 - A Fox, A Rabbit, and A Cabbage
Jun-11 04:19:59 INFO SEARCHQUEUE-BACKLOG-269613 :: Searching T411 for Fargo - 1x09 - A Fox, A Rabbit, and A Cabbage
Jun-11 04:19:58 INFO SEARCHQUEUE-BACKLOG-269613 :: Searching gks for Fargo - 1x09 - A Fox, A Rabbit, and A Cabbage
Jun-11 04:19:52 INFO SEARCHQUEUE-BACKLOG-269613 :: Clearing TorrentLeech cache and updating with new information
Jun-11 04:19:51 INFO SEARCHQUEUE-BACKLOG-269613 :: Searching TorrentLeech for Fargo - 1x09 - A Fox, A Rabbit, and A Cabbage
Jun-11 04:19:51 INFO SEARCHQUEUE-BACKLOG-269613 :: Searching for Fargo - 1x09 - A Fox, A Rabbit, and A Cabbage
Jun-11 04:19:49 INFO BACKLOG :: Seeing if we need any episodes from Fargo season 1
Jun-11 04:19:49 INFO BACKLOG :: Seeing if we need any episodes from True Blood season 7
Jun-11 04:19:49 INFO BACKLOG :: Seeing if we need any episodes from The Walking Dead season 5
Jun-11 04:19:49 INFO BACKLOG :: Seeing if we need any episodes from Le Trône de fer season 4
Jun-11 04:19:49 INFO BACKLOG :: Seeing if we need any episodes from Suits season 4
Jun-11 04:19:49 INFO BACKLOG :: Running limited backlog on recently missed episodes only
Jun-11 03:33:05 INFO SHOWQUEUE-REFRESH :: No new cache images needed, not retrieving new ones
Jun-11 03:33:05 INFO SHOWQUEUE-REFRESH :: Checking & filling cache for show Fargo
Jun-11 03:33:05 INFO SHOWQUEUE-REFRESH :: 269613: Writing NFOs for all episodes
Jun-11 03:33:05 INFO SHOWQUEUE-REFRESH :: 269613: Loading all episodes with a location from the database
Jun-11 03:33:02 INFO SHOWQUEUE-REFRESH :: 269613: Loading all episodes from the show directory /volume1/video/Series/Voir/Fargo
Jun-11 03:33:02 INFO SHOWQUEUE-REFRESH :: Performing refresh on Fargo
Jun-11 03:33:02 WARNING SHOWQUEUE-FORCE-UPDATE :: Unable to add TVRage info: urlopen call to http://services.tvrage.com/tools/quickinfo.php?show=Fargo failed
Jun-11 03:33:02 WARNING SHOWQUEUE-FORCE-UPDATE :: Timed out while loading URL http://services.tvrage.com/tools/quickinfo.php?show=Fargo
Jun-11 03:32:31 INFO SHOWQUEUE-FORCE-UPDATE :: Loading all episodes from the DB
Jun-11 03:32:31 INFO SHOWQUEUE-FORCE-UPDATE :: 269613: Loading all episodes from theTVDB...
Jun-11 03:32:29 INFO SHOWQUEUE-FORCE-UPDATE :: Loading all episodes from the DB
Jun-11 03:32:27 INFO SHOWQUEUE-FORCE-UPDATE :: 269613: Loading show info from IMDb
Jun-11 03:32:26 INFO SHOWQUEUE-FORCE-UPDATE :: 269613: Loading show info from theTVDB
Jun-11 03:32:26 INFO SHOWQUEUE-FORCE-UPDATE :: Beginning update of Fargo
Quelqu'un à déjà eu ce problème ?
Avez-vous une idée ?
Merci d'avance.
Modifié par obscur95
  • 3 semaines après...
Je n'utilise pas deluge ni n'ai eu de soucis de ce genre.
Je suggère de revérifier le paramétrage de la liaison entre SB et le client torrent et/ou de tester avec d'autres clients.
La liaison est bonne, puisque je n'ai aucun problème a snatcher depuis T411, GKS et CPASBIEN.
C'est pour cela que je ne comprend pas pourquoi ça ne fonctionne pas uniquement avec torreleech.
Un petit up.
Malgré les mises à jour qu'il y a eu, j'ai toujours le problème.
Si sarakha63 passe par la pour me donner une astuce ou autre.
Merci.
Mets tes logs en mode debug... je dis ça car cela ressemble à un problème que j'ai également!
Sep-03 22:33:44 DEBUG SEARCHQUEUE-BACKLOG-249882 :: DownloadStation: Exception raised when sending torrent: No JSON object could be decoded
Sep-03 22:33:44 DEBUG SEARCHQUEUE-BACKLOG-249882 :: DownloadStation: Failed Sending Torrent
Sep-03 22:33:44 DEBUG SEARCHQUEUE-BACKLOG-249882 :: DownloadStation: Not Found
AA"POST /webapi/DownloadStation/task.cgi HTTP/1.1" 404 381
Sep-03 22:33:43 DEBUG SEARCHQUEUE-BACKLOG-249882 :: DownloadStation: Requested a POST connection to url http://localhost:5000/webapi/DownloadStation/task.cgi with Params= {} Data={'session': 'DownloadStation', '_sid': u'zWPHE3thi3U1g13B0M8N000276', 'api': 'SYNO.DownloadStation.
AA"GET /webapi/auth.cgi?api=SYNO.API.Auth&version=2&method=login&account=XXXXXXXXXX&passwd=XXXXXXX&session=DownloadStation&format=sid HTTP/1.1" 200 81
AAStarting new HTTP connection (1): localhost
Sep-03 22:33:42 DEBUG SEARCHQUEUE-BACKLOG-249882 :: Calling DownloadStation Client
Sep-03 22:33:41 DEBUG SEARCHQUEUE-BACKLOG-249882 :: Picked XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX as the best
Sep-03 22:33:41 INFO SEARCHQUEUE-BACKLOG-249882 :: Quality of XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX is SD TV
j'ai désinstallé/réinstallé plusieurs fois (fork : https://github.com/sarakha63/Sick-Beard ; branche : master)
A noter : j'ai été obligé de dérouler cette procédure : http://sickbeard.com/forums/viewtopic.php?p=23028&sid=e49e11b05bdf0811bc864057dc08cfe4#p23028
lors de l'ajout d'une série, lorsque je choisissais le dossier parent dans l'étape 2, impossible d'accéder aux dossiers (j'entre dans volume1 et ensuite il ne se passe rien lorsque je clique sur un dossier). Un problème de droits même si aucune trace dans les logs.
Afin de tester tout cela, j'ai choisi une série qui existe sur T411 (j'ai cherché sur leur moteur de recherche d'abord). Je l'ai mise dans l'état "wanted" et j'obtiens les traces ci dessus...
j'ai beau chercher je ne vois pas comment faire sans aide d'un ou des développeurs...
Donc pour toi c'est sur T411 que ça ne snatch pas ? et uniquement T411 ?
Car pour moi, je vois bien qu'il snatch puisqu'il passe la ligne en violet (snatch) au lieu de rouge (wanted).
Mais quand je vais sur ma seedbox je ne vois pas le téléchargement et quand je vais sur mon compte torrentleech je ne vois pas non plus le téléchargement dans mon activité.
Et ça se produit uniquement sur torrentleech, les autres fonctionnent très bien.
Pour l'instant, je n'ai plus de série à télécharger, cela va reprendre fin septembre, à ce moment-là je mettrai les logs en débug et je l'ai posterai ici.
bon bah moi ça marche et je ne sais pas / plus ce que j'ai fait, pas fait... pfffff :)
Pour info, si je compare mon problème au tiens, moi aussi les séries passaient en "snatch" sans apparaitre dans le client torrent. Preuve que cela ne veut rien dire. ;)
il faut bien regarder les logs en mode debug, là au moins tu sais ce qu'il se passe.
  • 4 semaines après...
Hello,
Bon j'ai des séries qui recommence (comme NCIS et Agent du Shield), ça snatch toujours sur Torrentleech, mais ça ne met pas en téléchargement.
Pour les logs, malheureusement les logs disponibles dans sickbeard en mode débug ne remonte pas plus loin en arrière de 10 minutes à peu près. Le snatch se fait à 4h du matin donc je ne peux pas accéder au log de débug.
Il y a-t-il un moyen de mettre les logs de débug dans un fichier ? Ou de le récupérer d'une autre façon ?
Personne ne sait comment diriger les logs vers un fichier ?
Hello,
Je reviens de nouveau vers vous pour le même problème.
J'ai pas du ouvrir les yeux assez grand, mais il y a bien une fonction de log et j'ai pu récupérer les traces des snatch.
Exemple avec le dernier épisode de The Walking Dead:
Nov-03 04:51:17 DEBUG    SEARCHQUEUE-RSS-SEARCH :: Ep is wanted/unaired/skipped, definitely get it
Nov-03 04:51:17 INFO     SEARCHQUEUE-RSS-SEARCH :: Found result The.Walking.Dead.S05E04.720p.HDTV.x264-KILLERS at http://www.torrentleech.org/rss/download/556442/1e6eec7baf04f5f2576b/The.Walking.Dead.S05E04.720p.HDTV.x264-KILLERS.torrent
Nov-03 04:51:17 DEBUG    SEARCHQUEUE-RSS-SEARCH :: Picking the best result out of [u'The.Walking.Dead.S05E04.720p.HDTV.x264-KILLERS']
Nov-03 04:51:17 DB       SEARCHQUEUE-RSS-SEARCH :: sickbeard.db: SELECT episode_id from tv_episodes where tvdbid=? with args [5006708]
Nov-03 04:51:17 DB       SEARCHQUEUE-RSS-SEARCH :: sickbeard.db: SELECT link from episode_links where episode_id=? with args [3035]
Nov-03 04:51:17 INFO     SEARCHQUEUE-RSS-SEARCH :: Quality of The.Walking.Dead.S05E04.720p.HDTV.x264-KILLERS is HD TV
Nov-03 04:51:17 DEBUG    SEARCHQUEUE-RSS-SEARCH :: Picked The.Walking.Dead.S05E04.720p.HDTV.x264-KILLERS as the best
Nov-03 04:51:17 DB       SEARCHQUEUE-RSS-SEARCH :: sickbeard.db: SELECT count(*) from episode_links where episode_id=? and link=? with args [3035, u'http://www.torrentleech.org/rss/download/556442/1e6eec7baf04f5f2576b/The.Walking.Dead.S05E04.720p.HDTV.x264-KILLERS.torrent']
Nov-03 04:51:17 DB       SEARCHQUEUE-RSS-SEARCH :: sickbeard.db: INSERT INTO episode_links (episode_id, link) VALUES (?,?) with args [3035, u'http://www.torrentleech.org/rss/download/556442/1e6eec7baf04f5f2576b/The.Walking.Dead.S05E04.720p.HDTV.x264-KILLERS.torrent']
Nov-03 04:51:17 DB       SEARCHQUEUE-RSS-SEARCH :: cache.db: SELECT time FROM lastUpdate WHERE provider = ? with args ['cpasbien']
Nov-03 04:51:17 DB       SEARCHQUEUE-RSS-SEARCH :: cache.db: SELECT * FROM cpasbien
Nov-03 04:51:17 DEBUG    SEARCHQUEUE-RSS-SEARCH :: Calling Deluge Client
Nov-03 04:51:18 DEBUG    SEARCHQUEUE-RSS-SEARCH :: Deluge: Requested a POST connection to url http://IP SEEDBOX:PORT/json with Params= {} Data={"params": ["http://www.torrentleech.org/rss/download/556442/1e6eec7baf04f5f2576b/The.Walking.Dead....
Nov-03 04:51:18 DEBUG    SEARCHQUEUE-RSS-SEARCH :: Deluge: Response to POST request is {"id": 2, "result": null, "error": null}
Nov-03 04:51:18 DB       SEARCHQUEUE-RSS-SEARCH :: sickbeard.db: INSERT INTO history (action, date, showid, season, episode, quality, resource, provider) VALUES (?,?,?,?,?,?,?,?) with args [402, '20141103045118', 153021, 5, 4, 4, u'The.Walking.Dead.S05E04.720p.HDTV.x264-KILLERS', 'TorrentLeech']
Nov-03 04:51:18 DEBUG    SEARCHQUEUE-RSS-SEARCH :: 153021: Saving episode details to database
Nov-03 04:51:18 DEBUG    SEARCHQUEUE-RSS-SEARCH :: STATUS IS 402
Nov-03 04:51:18 DB       SEARCHQUEUE-RSS-SEARCH :: sickbeard.db: UPDATE tv_episodes SET status = ?, tvdbid = ?, hastbn = ?, airdate = ?, file_size = ?, description = ?, scene_episode = ?, location = ?, scene_season = ?, hasnfo = ?, audio_langs = ?, subtitles_searchcount = ?, release_name = ?, subtitles_lastsearch = ?, subtitles = ?, name = ? WHERE season = ? AND showid = ? AND episode = ? with args [402, 5006708, False, 735539, 0, u"La situation semble s'xeatre calmxe9e pour le groupe. En apparence, aucun danger imminent ne guette les survivants. Mais la situation se dxe9txe9riore. Beth, quant xe0 elle, se retrouve en dxe9licate posture dans un hxf4pital au beau milieu d'Atlanta. La jeune femme a xe9txe9 recueillie par un groupe de policiers aux intentions douteuses. Daryl et Carol sont sur sa piste, dxe9terminxe9s xe0 la retrouver.", None, '', None, False, 'en', 0, '', '0001-01-01 00:00:00', '', u'Slabtown', 5, 153021, 4]
Nov-03 04:51:18 DEBUG    SEARCHQUEUE-RSS-SEARCH :: Episode has no release name, replacing it with a generic one: %SN - %Sx%0E - %EN
Nov-03 04:51:18 DEBUG    SEARCHQUEUE-RSS-SEARCH :: formatting pattern: %SN - %Sx%0E - %EN -> The Walking Dead - 5x04 - Slabtown
Nov-03 04:51:18 INFO     SEARCHQUEUE-RSS-SEARCH :: Executing command ['/usr/syno/bin/synodsmnotify', '@administrators', 'Started Download', u'The Walking Dead - 5x04 - Slabtown on TorrentLeech']
Nov-03 04:51:18 DEBUG    SEARCHQUEUE-RSS-SEARCH :: Absolute path to command: /usr/syno/bin/synodsmnotify
Nov-03 04:51:19 DEBUG    SEARCHQUEUE-RSS-SEARCH :: Script result: synodsmnotify.cpp:172 Fail to send notify to @administrators
Voila si cela peux aider a résoudre mon soucie.
