Bootstrap Et Ipkg Dispos Pour Le Ds-508
Je ne dois pas être le seul a avoir testé ipkg sur DS-508, dispo sur http://www.maartendamen.com.
Bon, il y a le minimum syndical: :unknw:
DS-508> ipkg list
bzip2 - 1.0.5-1 - Very high-quality data compression program
dsx08-bootstrap - 1.0-0 - Bootstrap package for the DS-X08
ipkg-opt - 0.99.163-10 - The Itsy Package Manager
libdb - 4.2.52-3 - Berkeley DB Libraries
libstdc++ - 6.0.3-6 - Standard C++ library, needed for dynamically linked C++ programs
nano - 2.1.1-1 - A pico like editor
ncurses - 5.6-3 - NCurses libraries
ncursesw - 5.6-2 - NCurses libraries with wide char support.
openssl - 0.9.7m-4 - Openssl provides the ssl implementation in libraries libcrypto and libssl, and is needed by many other applications and librari
openssl-dev - 0.9.7m-4 - openssl native development files
par2cmdline - 0.4-4 - tool to apply the data-recovery capability concepts of RAID-like systems to the posting & recovery of multi-part archives on Us
py25-celementtree - 1.0.5-20051216-5 - A toolkit that contains a number of light-weight components for working with XML (C implementation).
py25-cheetah - 2.0.1-2 - Cheetah - The Python-Powered Template Engine.
py25-elementtree - 1.2.6-20050316-5 - A toolkit that contains a number of light-weight components for working with XML.
py25-openssl - 0.7-1 - Python wrapper around a small subset of the OpenSSL library.
py25-sabnzbd - 0.3.4-1 - A web-interface based binary newsgrabber written in python, with nzb file support.
py25-sabnzbd - 0.4.0-1 - A web-interface based binary newsgrabber written in python, with nzb file support.
py25-yenc - 0.3-1 - A module that provides only raw yEnc encoding/decoding with builtin crc32 calculation (C implementation).
python25 - 2.5.2-2 - Python is an interpreted, interactive, object-oriented programming language.
readline - 5.2-2 - The GNU Readline library provides a set of functions for use by applications that allow users to edit command lines as they are
sqlite - 3.5.9-1 - SQLite is a small C library that implements a self-contained, embeddable, zero-configuration SQL database engine.
unrar - 3.6.8-2 - unrar is an application that can decompress files and archives created using the RAR compression scheme
unzip - 5.52-3 - A (de)compression library for the ZIP format
wget-ssl - 1.11.2-2 - A network utility to retrieve files from the Web
zlib - 1.2.3-2 - zlib is a library implementing the 'deflate' compression system.
Successfully terminated.
Vivement la suite... :D
Bidule :shok:
Bonsoir
Impressionant!!! :yahoo:
Mon préféré: bitchx :lol:
Bidule :shok:
  • 3 semaines après...
est ce que vous pourriez nous donner des retours sur le boostrap et IPKG sur DS508 ? Est ce que ca marche ? Avez vous eu des problèmes pour l'installer ?
J'ai une forte envie de l'installer, mais j'ai lu des topics comme quoi le boostrap adapte par Maarten etait plein de bugs.
http://www.synology.com/enu/forum/viewtopi...f=40&t=8199
Merci !
ipkg installé avec succès au premier essai :yahoo: (pour une fois! ;) )
nano a une petite spécificité, ( ne suis pas le redimensionnement de la fenetre :unknw: ), dnsmasq installé avec succes, net-tools et c'est à peu près tout pour le moment...
Bidule :shok:
  • 2 mois après...
Bidule :shok:
tu as trouvé ou ton paquet nano ?
lorsque je fait la commande "ipkg update"
il essaye de se connecter sur un site internet et beug avant de commencer le telechargement,
l'erreur est la suivante :
ipkg update
Downloading http://www.maartendamen.com/synoware/x08/Packages
An error ocurred, return value: 1.
Collected errors:
ipkg_download: ERROR: Command failed with return value 1: `wget --passive-ftp -q -P /opt/ipkg-boqp9I http://www.maartendamen.com/synoware/x08/Packages'
Avez-vous une idée concernant la source de ce problème ?
ipkg update
Collected errors:
j'ai oublié, merci d'avance :)
Nano n'est pas dispo dans le repository par défaut qui est peu fourni, il faut changer la source des packages par celle ci
http://ipkg.nslu2-linux.org/feeds/optware/syno-e500/cross/unstable/
dans la configuration d'ipkg Pour qu'ipkg ne cherche plus dans l'ancien repository mais dans celui de nslu2, il y a quelques modifications à faire. Si la config du bootstrap fonctionne de la meme façon que sur le 407/107+/207+ (ce qui est très probable) il faut alors procéder comme suit: 1. ouvrir le fichier /opt/etc/ipkg.conf en tapant sous telnet vi /opt/etc/ipkg.conf 2. Remplacer la ligne
src synoware http://www.maartendamen.com/synoware/x08/Packages
par
src synoware http://ipkg.nslu2-linux.org/feeds/optware/syno-e500/cross/unstable/
puis sauvegardez le fichier
3. on met à jour la liste des packages disponibles en tapant ipkg update
4. on crée le repertoire init.d qui sera nécessaire pour certains packages s'il n'existe pas encore: mkdir /opt/etc/init.d
C'est fini !
  • 4 semaines après...
Merci pour le tuyeau, ca a l'air de marcher nikel sur un 508, juste un détail, le nom de variable a changé : c'est :
src synoware08 http://www.maartendamen.com/synoware/x08/Packages
à remplacer par :
src synoware08 http://ipkg.nslu2-linux.org/feeds/optware/syno-e500/cross/unstable/
